Crazy Talk 6 not recording all the face movement
Crazy Talk 6 not recording all the face movementExpand / Collapse
Posted 11/19/2009 2:27:36 PM
Newbie
Last Login: 11/20/2009 1:34:41 PM
Posts: 2, Visits: 3
Hi
I am having an issue with Crazy Talk 6. I record a clip and in the time line mode it records all the face movements well. Then I go into stage mode and only the first 30 seconds work. I have tired altering the project length.
It also seem to be very random somethings its OK and sometimes not.
I have a 64 bit computer running VISTA home 64bit
Any help would be appreciated as it is slowing me down
Thanks
Nick
Post #32520
Posted 11/19/2009 7:59:53 PM
Last Login: Yesterday @ 11:51:21 PM
Posts: 3,801, Visits: 6,294
Hi Nick,
The only time you should be limited to 30 seconds is when using the trial version.
The way it should work is once you have recorded your vocals, you will then have a CTS script. The length of this script is displayed under the Project Length when you are working on your script. If you then change Project Length to match the total CTS Length then the project should run perfectly.
NOTE: You do have to hit Enter/Return to set any changes you make in the Project Length box. If you don't it will revert back to the default time.
So when you record your vocals, say for 1 minute, and then you check the CTS length it only shows as 30 seconds. Is that correct?
Peter Edwards
Post #32548
Posted 11/20/2009 1:36:02 PM
Newbie
Posts: 2, Visits: 3
Thanks for your help
It is very fragile and I have managed to get it to work by clicking on the audio track and draging it to the right and then to the left. I have a fully paid up licence, love the product but I think there is a small bug here.
Nick
Post #32609
Posted 12/10/2009 10:20:26 AM
Newbie
Last Login: 12/10/2009 10:20:26 AM
Posts: 1, Visits: 2
Hello, I am glad to find out the solution which is a bite not userfriendly for a poor French without any document to refer to.
A fix will be very appreciated
Bonne journée
Post #34358
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 12:00pm
Execution: 0.188. 10 queries. Compression Enabled.
