| | | Newbie
Group: Forum Members Last Login: 10/8/2007 11:51:27 AM Posts: 4, Visits: 4 |
| I know that this was not possible in version 1.5 but in version 2? Everytime I try to add more characters, it replaces the first character that I added..... Please don't tell me that this is not possible. I am a pretty smart person but this escapes me. Thanks!
Tom
Tom Rennen
http://www.tomrennen.com
Intelligent Light LLC
"Tools will never take the place of talent" |
Skype ID= learn.iclone
Group: Senior Forum members Last Login: Today @ 9:18:01 AM Posts: 562, Visits: 2,359 |
| Try CTRL-F7 to add more characters, then Move the Character using Modify. It was available in 1.5 by the way.
| tom (9/20/2007) I know that this was not possible in version 1.5 but in version 2? Everytime I try to add more characters, it replaces the first character that I added..... Please don't tell me that this is not possible. I am a pretty smart person but this escapes me. Thanks!
TomHi Tom, When you Press CTRL-F7 and click the Add button you will have two characters listed in the drop down list box. Check to see that you have the two characters. They will be named by default, Character 0 and Character 1 (You can change the names to anything you want). As Cricky has already mentioned, moving the first character to the left or right before adding a second character will make it easier to see the two different figures. From then on you just select the one you want to make changes to from the drop down list after pressing CTRL-F7 again.
| | | | Newbie
Group: Forum Members Last Login: 5/28/2009 3:17:44 AM Posts: 1, Visits: 13 |
| | I tried to add a character using the ctrl F7 and nothing happened. I understand how it is to work. But I got none of the boxes in the modify tab. |
Group: Senior Forum members Last Login: Today @ 7:49:44 AM Posts: 838, Visits: 3,955 |
| | Make sure you have Character and Template selected when you hit Ctrl F7, the add Character box should appear in your main iClone window.........just a thought to try Shy
| marcelj29 (9/22/2007) I tried to add a character using the ctrl F7 and nothing happened. I understand how it is to work. But I got none of the boxes in the modify tab. Hi, Try loading the default character and without making any changes to the scene press CTRL-F7. You should get the Character Selection Panel open so you can add another character.
Every character in iClone has a section called Character Position under the Modify tab. It is right at the bottom so scroll down to see it. It is from here that you move your character to a different position.
I hope this makes things clearer for you.
