CrazyTalk won't start
CrazyTalk won't startExpand / Collapse
Posted 11/15/2009 7:49:25 PM
Veteran
Last Login: Today @ 1:25:36 AM
Posts: 279, Visits: 404
After I installed CT 5.1 Pro on a new pc with Windows 7 home premier OS, I couldn't get it to start. When I double clicked at the CT icon, it came up with the following message:
"1024 x 768 or higher display resolution required, change your display settings and try again"
There are 2 monitors attached to this pc. One is at 1920 x 1080, the other 1280 x 1024. Both resolutions are higher than 1024 x 768.
I uninstalled CT, did a re-download from RL and installed again. Still the same message. It was running fine in my old pc with Windows XP as OS.
Any ideas?
Thanks,
David
Post #32218
Posted 11/17/2009 7:07:13 PM
Last Login: Yesterday @ 11:51:21 PM
Posts: 3,801, Visits: 6,294
Hi David,
Have you tried temporarily switching to a single display setup and see if Crazytalk will start? It would appear something is causing Crazytalk to think your display is at a very low resolution.
Please contact Technical Support for help with this. You can use the link below for the fastest response.
Thanks.
Peter Edwards
Post #32381
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 12:54pm
Execution: 0.172. 10 queries. Compression Enabled.
