Eyes and window size
Eyes and window sizeExpand / Collapse
Posted 11/7/2009 5:20:57 PM
Veteran
Last Login: Yesterday @ 11:44:09 PM
Posts: 164, Visits: 232
I've got two questions.
1. I want to change the eye color using the color adjest sliders. That's all good when I'm changing one of the preset ones, but I have a few custom eyes taht I made that only considst of a single picture on each eye. I can't change the colors. How can I make it so I can do this?
2. Everytime I minimize and maximize the iClone window, it gets too big for my screen. Well it's not everytime, but it's a lot of the time. And even moreso when the timeline's there. I can deal with it but just wondering why sometimes it's too big for my screen.
Post #31411
Posted 11/9/2009 8:31:23 AM
Veteran
--bump--
It's ok if you guys didn't reply to my other topic I guess.
But I really would like some help on this one please.
Also another question. After loading a preset head, I can't click on the Heads section of the face modify panel for some reason. It greys out. Why is that? Thanks.
Post #31574
Posted 11/9/2009 11:33:26 AM
Group: Senior Forum members
Last Login: Today @ 3:11:51 PM
Posts: 1,143, Visits: 5,335
Dream if you want to edit existing heads- click on AVATAR and SKIN then use the drop down menu in the right MODIFY panel to select FACE - then use an external photo editor to make changes
Post #31596
Posted 11/9/2009 5:21:07 PM
Veteran
Thanks. But I was talking about the headshape. I suppose that does work for the eyes though although it's a slight bit more tidious.
Post #31623
Posted 11/10/2009 10:38:55 AM
Last Login: Today @ 2:53:12 PM
Posts: 3,322, Visits: 5,639
Dreamcube017 (11/7/2009)
Are you using a single or dual monitor setup? Also what resolution you are using?
If you are using a single monitor then clicking "Maximize" should fill up the screen to the resolution set in your display properties. This window is not adjustable and no part of iClone should be outside the screen.
If you click "Restore" to return iClone to a window, it can then be adusted by dragging the corners to get the desired size. This can be to the full size of your display if you wish.
I would check your Display Properties and make sure your monitor is correctly setup (install drivers if you have them) and make sure you are using resolution supported by your monitor of at least 1024 x 768 in size.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #31710
Posted 11/10/2009 2:55:45 PM
Veteran
Thanks. LIke I said, it doesn't happen all the time, just sometimes. I'm using a signle monitor. My resolution is 1360x768.
Maximizing works sometimes but othertimes it makes it so the timeline is off the screen... I mean the advanced timeline.
Maybe NVIDIA came out with a driver update that I didn't hear about. Hmm.. Thanks again.
Post #31744
Forum Moderators: Visconti, Peter Edwards
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 3:24pm
Execution: 0.141. 6 queries. Compression Enabled.
