Cany Uninstall...
Cany Uninstall...Expand / Collapse
Posted 11/2/2009 6:29:46 PM
Last Login: 11/6/2009 8:21:11 PM
Posts: 20, Visits: 40
So I think I have a virus and need to reinstall CrazyTalk 6. The problem is that when I try to uninstall the program through "Add/Remove Programs" I get an error message saying "Setup has a problem and needs to close". I am able to remove many other programs, just not CrazyTalk. Is there a solution...or workaround? Please help. Thank you.
Post #30749
Posted 11/2/2009 7:04:20 PM
Posts: 3,319, Visits: 5,635
If you are unable to uninstall Crazytalk 6 then you will still be able to install it again as long as you have not used up all the 5 clean installs allowed.
If you are planning a full reinstall of the Operating System then Crazytalk 6 will be removed during that process. Then you can install it again afterwards. Uninstalling Crazytalk 6 if you still have a virus won't make any difference. You need to clean your system completely first.
If you don't plan to reinstall the OS then please contact Support for assistance in removing Crazytalk 6.
Please use the link below.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #30756
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 2:43am
Execution: 0.156. 10 queries. Compression Enabled.
