bogdanB
bogdanB
Last Active: 7 Years Ago
Visits: 28
Hello. I have just made a new character in character creator and export it. When I try to load it in iclone 6 an error appears that says "failed to load file". Any solutions, or can anyone tell me what am I doing wrong? TY!
Lawsuit Pending Records
Visits: 2.1K
Are you exporting via iAvatar or using Send to iClone? Sounds a little unusual for CC > iClone to go pear shaped.
iC5 Pipeline, iC6 Pipeline, CTA2 Pipeline, CTA Pro, Crazy Talk, Facefilter, POP. LAWSUIT PENDING RECORDS - Label-Logos-Web Design-Artist Roster-Licensing - Flip type interactive magazine production
Last Active: Yesterday
Posts: 5.7K,
Visits: 26.4K
Can you provide some more details please, regarding the settings that you used. Are you using the latest versions of both Character Creator and iClone?
Last Active: 7 hours ago
Posts: 22.7K,
Visits: 35.7K
bogdanB (7/19/2016) Hello. I have just made a new character in character creator and export it. When I try to load it in iclone 6 an error appears that says "failed to load file". Any solutions, or can anyone tell me what am I doing wrong? TY!Do make sure you have updated iClone and 3DXchange to version 6.5 and Character Creator to version 1.5. This issue normally occurs when you don't have all programs updated to the same matching version.
8 Years Ago by
ninjahiden
ninjahiden
Visits: 7
hi! i install iClone 3DXchange v6.2 Pipeline and iClone v6.11 PRO now i have some problem to import any file to iClone v6.11 PRO just show mi Failed to load file and click {ok} after click noting! i just waste all my time for a model! Please help as tnx
Posts: 5.7K,
Visits: 26.4K
ninjahiden (8/2/2016)
hi! i install iClone 3DXchange v6.2 Pipeline and iClone v6.11 PRO now i have some problem to import any file to iClone v6.11 PRO just show mi Failed to load file and click {ok} after click noting! i just waste all my time for a model! Please help as tnx You need to install the latest versions of the software. At the moment iClone and 3DXchange are version 6.51 and Character Creator is version 1.5. You can download all the latest versions - including patches - from your Reallusion account. For iClone 6.51 you will also need to download and install the new Resource Pack. If you are too many versions behind the newest available then it would be better to first uninstall the older software and do a clean reinstall.
8 Years Ago by
Last Active: 2 hours ago
Posts: 15.7K,
Visits: 30.5K
Like wires said. Also, the versions of 3DXchange and iClone need to be the same. So files from 3DXchange 6.2 will not load in iClone 6.11.
toystorylab
toystorylab
Last Active: Today @ 4:32 AM
Posts: 4.4K,
Visits: 28.8K
wires (8/2/2016) [quote]ninjahiden (8/2/2016)
I did not do that... Do i simply install this? It probebly will overwrite a lot?
ninjahiden
ninjahiden
Visits: 7
thank you for all !!! i fix it simple with $
Posts: 5.7K,
Visits: 26.4K
toystorylab (8/3/2016)
I did not do that... Do i simply install this? It probebly will overwrite a lot? The new Resource Pack will only overwrite default content that has been updated, it does not change, or remove, any purchased and custom content.
