| | | Veteran
Group: Forum Members Last Login: Yesterday @ 11:44:09 PM Posts: 164, Visits: 232 |
| I'm trying to build something and it's made up of a lot of parts and I'd kind of like to save them as props to use later.
Is that possible? It doesn't look like it which is somewhat disappointing. I can save single props... but that's just like resaving a 3D block but just with a texture... That doesn't seem very useful.
Is there a way I can group the blocks so I can save them as props? Thanks. |
| | | | Junior Member
Group: Senior Forum members Last Login: 11/12/2009 3:24:37 AM Posts: 23, Visits: 358 |
| Hi,
Try use "Attach" function in Props>Modify>Attach, click Pick Parent
After then, you may click "Merge" to merge the two props to one. |
Veteran
Group: Forum Members Last Login: Today @ 12:35:49 PM Posts: 293, Visits: 759 |
| | | | | Veteran
| Ah ok thanks.
Another question, can we really import spring properties to any 3D object?
Well I think it worked because I had for things and I just attached prop 1 to prop 2 and attached prop 2 to prop 3, and attached prop 3 to prop 4 and then MERGE and it worked out. |
| | | | Junior Member
| Hi, Gorz,
Wow... I find that iClone4 is now allow multi level for Attach
Try it!! |
