Newbie
Group: Forum Members Last Login: 2/26/2010 3:07:30 PM Posts: 9, Visits: 36 |
| Can someone PLEASE point me a a tutorial that will help me become non-HUA with this feature?
I Export and get a Widget file. I don't see what I'm supposed to see. I get a widget file that won't play. If I try to edit... it tells me I need a newer version. I export to a Flash file and get a file with all of the Avatar Scripts... but it just plays through. No cursor following.
I'm clueless, tense, and cranky.
Mac
"Fail to suck" |
Group: Administrators Last Login: Yesterday @ 9:58:41 PM Posts: 3,803, Visits: 6,303 |
| | Hi Mac, I'm not entirely sure what you want to do with the outputted content but all export options of Crazytalk 6 are video or Widget based. For the video options you can use AVI, WMV, Flash etc. Once outputted, you can watch this content on your chosen video player suich as Windows Media Player, VLC etc. For export to Widget, you will need WidgetMe or WidgetCast to use this type of output. You can find out more about WidgetCast and its uses Here. Also remember you can press F1 when in Crazytalk and bring up the Help Guide. This will explain all about the output features of CT6. Hope this helps.
Newbie
| Peter,
Maybe I'm not too sure either. That might be the problem.
What I want to do is use the Web Avatar Man... change the model... and then Export it (the cursor following Avatar) and the HTML code to something I can use on a web page.
I've watched the Tutorial. But I must be too Stoooopud because I can't figure it out.
Thanks,
Mac
"Fail to suck" |
Newbie
| Ok... I think I'm square now. Apparently I started with Lolita.
Thanks for your help.
Mac
"Fail to suck" |
