Dear Joshua,
When you export FLASH file, you should get .flv, AC_RunActiveContent.js, FlashSwf.swf in a folder. You have to convert the FLV format to SWF format through third-party converter such as 4U FLV Converter and so on. Then, you can insert this SWF file into your webpage via webpage editor such as Dreamweaver and so on.
If you want to stop the FLASH looping, you have to add several HTML codes: <param name="LOOP" value="false"> and loop="false in <object>.
e.g. <object classid="clsid27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,29,0" width="320" height="240">
<param name="movie" value="da/001.swf">
<param name="quality" value="high"><param name="LOOP" value="false">
<embed src="da/001.swf" width="320" height="240" loop="false" quality="high" pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash"></embed>
</object>
Yours sincerely,
Mick
Technical Support
Reallusion Inc.
15 Years Ago by
Mick
