Group: Forum Members Last Login: 10/31/2009 10:25:30 PM Posts: 63, Visits: 266 |
| | can iclone 3 be installed on 2 computers as long as you dont use them at the same time |
Group: Administrators Last Login: Today @ 2:20:57 PM Posts: 3,321, Visits: 5,638 |
| Yes it can as long as only one is in use at any one time.
| | will this count as one of my installs if i install iclone 3 on a second computer please sir |
| Yes it will count as one of your 5 installs. That is why it is very important to uninstall while connected to the internet if you change or upgrade your computers. This way you will get the install credited back to you.
| | when iclone new version comes out and i upgrade to the new version is it then considered to be like two products each with the 5 installs |
| | because what if you purchase the upgrade and didnt realize you were out of installs as i have had some computer hard drive failures over time etc.. I take it you could go to install the upgraded iclone 4 and it wouldnt install as you might have exceeded your max installs ? |
| musicaz (9/15/2009) when iclone new version comes out and i upgrade to the new version is it then considered to be like two products each with the 5 installsWhen it comes to your install count, iClone3 and iClone4 are treated separately. Nothing carries over so if you upgrade to iClone4 you will start with 5 installs for IC4 regardless of what you had remaining with IC3.
Group: Forum Members Last Login: Today @ 11:55:28 AM Posts: 30, Visits: 583 |
| I have been reading all the discussion about install counts here and it just dawned on me to ask, Where do i look to see how many installs i have left for each product ?
Thanks |
| nlprod1 (9/15/2009)
I have been reading all the discussion about install counts here and it just dawned on me to ask, Where do i look to see how many installs i have left for each product ?  Thanks The install count is shown at the end of the installation process for iClone or Crazytalk. It will tell you the total allowed and your current number of installs.
