| | | Newbie
Group: Forum Members Last Login: 1/21/2010 8:25:43 PM Posts: 7, Visits: 12 |
| | Hello. I had recently purchased CloneCloth for the program iClone. I am still new to this program and I do not know all of the settings. When I applied the basic CloneCloth outfits to my iClone avatar, it turned blurry. And also, the farther back I go, the more distorted it becomes. And on the CloneCloth example images, theirs are nice and crisp. I would like to know if or where I could change this on the settings. Thank you, Kelly |
Group: Administrators Last Login: Yesterday @ 11:30:05 PM Posts: 3,802, Visits: 6,295 |
| | Hi Kelly, First thing to check is that you have a fairly high resolution set in the Real Time Map Size. Just go to Preferences (Hammer icon, top right) and set the size to something that will give you sharp textures in the preview window. Try a setting of at least 2048 x 2048 if your graphics setup can handle it.
Once you do this you should see the CloneCloth (and all other) textures looking sharp and clear. You should also make sure you have updated your graphics drivers to the latest available for the best results.
Group: Senior Forum members Last Login: Today @ 9:36:54 AM Posts: 1,363, Visits: 6,214 |
| i ran into this recently and even adjusting real map size did not help out -what i found was in my case i use ati 4850 graphics card and catalyst driver 9.4 is the only one that worked and showed clear textures - 9.5 to 9.8 all resulted in blurry textures
www.animatechnica.com |
Group: Forum Members Last Login: Today @ 4:39:14 PM Posts: 426, Visits: 1,214 |
| | | | | Newbie
| Thank you all so much! |
