face profiles in crazy talk 4
face profiles in crazy talk 4Expand / Collapse
Posted 9/12/2009 10:58:27 AM
Newbie
Last Login: 11/11/2009 10:01:34 AM
Posts: 4, Visits: 6
Does anyone have any tips for working with the wireframes to animate decent looking profile views in Crazy Talk 4.6? I could really use some help with that... I know version 6 has everything I need and want and can't live without but for now I have to stick with 4.6 - my boss just cut my work hours, so while I have more time to play with Crazy Talk, I got less money to spend on upgrades....
Post #25877
Posted 9/13/2009 6:15:52 PM
Posts: 3,319, Visits: 5,635
If you are trying to animate a full side on view then this is not really possible with Crazytalk 4.6 I'm afraid. The software is designed to work with forward or slightly angled facial images, not those from the side on. If you would like to explain more about what you are trying to achieve then I'll be glad to try and help further.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #25948
Posted 10/26/2009 10:27:27 PM
Newbie
Last Login: 11/5/2009 5:37:09 PM
Posts: 11, Visits: 15
Peter Edwards (9/13/2009)
If you are trying to animate a full side onview then this is not really possible with Crazytalk 4.6 I'm afraid. The software is designed to work with forward or slightly angled facial images, not those from the side on. If you would like to explain more about what you are trying to achieve then I'll be glad to try and help further.
OK, not possible in version 4.x
Are you saying a full on side view is possible with version 6?
Post #30103
Posted 10/26/2009 11:53:08 PM
Newbie
Posts: 4, Visits: 6
I managed to get it to work reasonably well in 4, just a lot of trial and error. You need to use the full wireframe view and drag all the points to one side and keep previewing and rearranging and masking. Just keep playing with it, at least till you are able to upgrade. I just can't justify the extra expense to upgrade right now.
Post #30110
Posted 11/5/2009 1:59:46 PM
Newbie
jerie (10/26/2009)
Hi Jerie,
Can you tell me a little more about your approach for a profile? I understand what the full
wireframe view is, but by draggin all the points to one side, do you mean we are essentially
folding the frame model in half? So that both of the "ear" points are on one side?
I could definitely see how masking the empty space would help. I assume that is what you mean.
Thanks for the encouragement.
Post #31150
Posted 11/11/2009 10:06:46 AM
Newbie
Posts: 4, Visits: 6
Hi, I'm afraid I have no procedure, it's really trial and error. Start by dragging all the points to one side as evenly as possible, test, mask whatever areas shouldn't move and note what areas should move but aren't, re-drag the points, test again, mask again, drag again, and so on. It isn't perfect but it works for now. Good luck!
Post #31833
« Prev Topic
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 3:27am
Execution: 0.078. 9 queries. Compression Enabled.
