my first iCloneCloth Clothes...and FREEBIES 4u....
12>>
my first iCloneCloth Clothes...and FREEBIES 4u....Expand / Collapse
Posted 8/29/2009 3:28:39 AM
Last Login: 12/9/2009 5:01:18 AM
Posts: 82, Visits: 309
this is my first attempt at clonecloth...I painted a JaneCloneCasual (G2 CloneCloth V1) Upper Body template purple then painted in shadows, then adjusted the contrast/brightness,hue & saturation to get the end result color.....
for the pants, I added a leather diffuse material to JaneCloneCasual's Lower Body then adjusted the contrast/brightness,hue & saturation to get the end result color.....and then adjusted JaneCloneCasual's tennies by using a negative effect filter.,you should be able to adjust any of these items to your preferred colors,etc.
i tried posting a zip file, but it didn't work out, so please check below for the thread i added the widget to.....
this gif animation demonstrates the items in the widget; sweater, pants, tennis shoes.
check out my 3D Creations Thread ;
(free downloads of 3D vases, wineglasses, cups, candleholders, bowls, flower pots, etc...new items will be added weekly.... downloads are .vns format)
free- 5 Goblets (or wineglasses, candleholders, vases, etc.)
Post #25021
Posted 8/29/2009 5:03:49 AM
Last Login: Yesterday @ 11:18:57 AM
Posts: 559, Visits: 810
I've not downloaded Mary, but it looks to me as if you have done a great job. Certainly much better than my first and very few efforts. Sorry to add a small negative, but I think I do notice in your .gif a small amount of skin showing through the pants on Jane's RH upper inner thigh. Well I would would'nt I? Its only a puppet!!! This if I'm correct could be either in the diffuse or  opacity map or could just be an anomaly.
gizmo
Post #25028
Posted 8/29/2009 6:05:12 AM
hey, gizmo !....yeaup, i thought i noticed an 'oddity' there, too, but wasn't sure...so after you mentioned it, i went n ran a test on it..i've put 3 mods in this gif,, n you can check it out, lmk if you still think it was skin, or just a reflection of the light hitting the material, (or showing thru her legs) etc....i used the leather material for the diffuse, but i didn't change the opacity map or opacity adjustments at all, but lmk...
Post #25031
Posted 8/29/2009 6:28:40 AM
Hi Mary. Certainly looks OK now. Keep it up.
gizmo
Post #25034
Posted 8/29/2009 6:57:16 AM
okie dokie...btw, don't know why, but in that first gif, the pants look really dark, (almost black, really)  ,,n I didn't adjust the lighting when i made the second gif, but it turned out alot lighter, so now u can see the details of the pants.,,but anyhows, i appreciate your concerns, n if anyone does have any problems with it after downloading, I guess they can just lmk n i'll discard it....well thanks again for checking my freebies out....ttyl
Post #25038
Posted 8/29/2009 7:09:31 AM
Group: Senior Forum members
Last Login: Yesterday @ 3:52:31 PM
Posts: 1,043, Visits: 4,675
Nice work Mary
Shy
Post #25039
Posted 8/29/2009 3:04:28 PM
Last Login: Today @ 12:09:07 AM
Posts: 1,344, Visits: 6,164
very nice job Mary! keep at it
Statements made above may be fact based or are my opinion only which are sometimes right but are never wrong
www.animatechnica.com
Statements made above may be based on fact or my opinion only which are sometimes right but are never wrong
Post #25046
Posted 8/29/2009 7:53:50 PM
Last Login: Yesterday @ 10:17:15 PM
Posts: 3,753, Visits: 6,225
You've made a great start with CloneCloth Mary. Well done.
Peter Edwards
Post #25052
Posted 8/30/2009 11:40:31 AM
Newbie
Last Login: 2/19/2010 9:15:07 AM
Posts: 7, Visits: 51
I just tried to download the Zip.  It downloads, but it is corrupt.  Tried several times.  Same thing.  Nice work by the way.  Keep it up.  I hope that you can supply another zip.  Thanks.
"If it's not fun
why do it?"
Post #25073
Posted 8/30/2009 3:52:34 PM
thanks Shy, aknzrdude, Peter, inetsfr....inetsfr, I just can't seem to get the zip to act right,but i've created a widget, so i'm posting it...you should be able to get the files from the widget, if you can't or don't know how, hollar back at me..
i've also included an extra sweater without the shadows (the shadows are ok from a distance, but up close they still need some tweaking)...well lmk how it goes...
Post #25077
12>>
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 12:17am
Execution: 0.172. 8 queries. Compression Enabled.
