iClone 3 - Earth?
iClone 3 - Earth?Expand / Collapse
Posted 8/28/2009 3:02:29 PM
Newbie
Last Login: 9/5/2009 8:22:07 PM
Posts: 3, Visits: 10
Hello,
Please provide me the steps for creating "3d Earth" using iClone 3. I appreciate your help.
Thank you,
Jack
Post #25001
Posted 8/28/2009 3:33:18 PM
Last Login: Yesterday @ 11:44:06 AM
Posts: 463, Visits: 681
Hi Jack.
Select Set, Props, 3D blocks and double click on a ball prop to select a ball. Go to Modify panel and click Diffuse. Below that you will see a small Folder icon next to UV Ref which says Open when you hover over it. Click on that and select your required jpeg of the 'earth'. You then may or may not have to play around with the UV settings below that to get what you want. i.e click on 'box' or 'spherical' and/or the X,Y or Z, offset, tiling or rotate options, then Apply button to get your desired effect.
Welcome to the Forum.
gizmo
Post #25004
Posted 10/16/2009 3:32:29 PM
Newbie
Last Login: 10/19/2009 2:10:23 PM
Posts: 8, Visits: 14
i try tho some thing like thate .
i have only sreenshot from it
ok a sig me bad
Post #28727
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 11:06am
Execution: 0.203. 9 queries. Compression Enabled.
