Suggestions
SuggestionsExpand / Collapse
Posted 12/21/2007 10:00:54 AM
Newbie
Last Login: 10/21/2009 2:31:33 PM
Posts: 3, Visits: 18
Hello,
the survey when ending the program doesn´t work, so i write my suggestions into the forum.
  • Startup: It should be possible to start the program without model/script.
  • Model: A great step forward is, that the control points are now connect with bezier lines. The ability to change the anchor points (angle between the lines) would be nice too.
  • A hair outline, which affects head movement but not facial distortion
  • Rotating the outlines in (pseudo)3d space (x/y axis) for better fitting (for example half profile).
  • Ability to create custom profiles
  • Custom eyes/teeth are hard to handle, there should be a possibility to distort them (perspective) and to resize x/y axis separately (eyes)
  • It would be nice to take the original eyes/teeth direct from the photo.
  • Puppeteering Mode: A play button, which can be switched on/off and plays the script while testing puppeteering.
  • More morph targets in p-mode, like in "creating key" mode.
  • Set key: a link button on symmetrical targets (links right with left brow, for example)
  • Timeline: The facial animation track could be expandle with sub tracks for all morph targets, to set the keypoint individually,  with different types of interpolation (linear,cubic,bezier,constant).
Just some ideas.
I great programm, i already ordered the update.
more to come...
Post #2483
Posted 1/8/2008 6:52:47 AM
Newbie
just suggestions NO complaints.
  • The jaw movement goes to far, even with small values
  • Sometimes a jitter occurs, when recording in puppeteering mode (when recording over a previous animation to add blinking).
  • Ability to exclude blinking from global morph strength to prevent half closed eyes, when lowering the global expression amount
  • A grid in the timeline to set frames accurate
  • When exporting i had an error, that my HD was full. Of course i had 100 GB free space.
  • Puppeteering mode: ability to enter negative values.
  • The sliders which can have a negative value (jaw left rigt, f.e.), should have a dot in the middle, that you can see wherer "zero" is. Or a "reset button.
Post #2654
Forum Moderators: Visconti, Peter Edwards, Phil_20090922184357260
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 3:05pm
Execution: 0.188. 10 queries. Compression Enabled.
