Can't export Alpha Channel - Iclone crash
Can't export Alpha Channel - Iclone crashExpand / Collapse
Posted 8/8/2009 1:48:52 PM
Newbie
Last Login: 8/8/2009 1:40:18 PM
Posts: 1, Visits: 1
Visual c++ runtime library runtime error, no exception code, contact the application support team
when rendering 1500x1500 transparent GIF sequence.
TGA files are not rendering with an alpha channel.
I am trying to export with an alpha channel for composition in After effects.
Any suggestions? anywhere an error log is found?
Please advise.
it's not a problem with the system, it's a high performance system that renders fast.
Post #23740
Posted 8/8/2009 2:15:57 PM
Last Login: Yesterday @ 9:58:41 PM
Posts: 3,803, Visits: 6,303
Please report this to Technical Support who will be able to advise you about this issue. You can use the support form linked below for the quickest response.
Thanks.
Peter Edwards
Post #23744
Posted 8/8/2009 3:38:53 PM
Group: Senior Forum members
Last Login: Yesterday @ 10:02:15 PM
Posts: 1,367, Visits: 6,217
if you are gonig to composite it with after effects anyway just export image sequence bmps with green background and chroma key in after effects
www.animatechnica.com
Post #23750
Forum Moderators: Visconti, Peter Edwards, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 1:51am
Execution: 0.219. 11 queries. Compression Enabled.
