| | | Newbie
Group: Forum Members Last Login: 8/10/2009 2:03:23 AM Posts: 2, Visits: 19 |
| I have now looked at every tutorial and help file I could find.
CrazyTalk 6 Pro
I import a .png image with a transparent background created in Photoshop, but the image does not show the transparency in CrazyTalk.
I go through all the steps as per the tutorials and when I export the project as a .flv the transparency does not show, in stead there is a white background.
I am trying to use the crazytalk project in Adobe Flash and it is supposed to go as a layer on top of a moving background. That is the reason it has to be transparent.
I'm obviously missing something, but what?
Can somebody please help. |
| | | | Newbie
| | Please tell me if it can be done, and if so, how? |
Group: Administrators Last Login: Yesterday @ 9:58:41 PM Posts: 3,803, Visits: 6,303 |
| | Hi, When you load your PNG image into Crazytalk 6, are you able to add a background to it that displays behind the character? If so then you will have successfully loaded an image with a alpha channel transparent backround into CT. You can then add your chosen backgrounds and do the work in Crazytalk itself. When it comes to outputting content with a transparent background your options are Sequence PNG, TGA or BMP. You can also use .iWidget format to output a character with a transparent background for use in WidgetMe and WidgetCast. Your other option is to output with a green or blue screen and do the chroma key work in a video editor. Most video editors support this technique.
