Problem selecting vertices in 3ds
Problem selecting vertices in 3dsExpand / Collapse
Posted 8/1/2009 4:06:38 PM
Last Login: 11/18/2009 1:56:10 PM
Posts: 52, Visits: 156
I can only select 24 vertices from the G2 template when the manual says 28. Is this a typo?
Also the manual says on pg 30 of the RLguide to name the upper and lower border vertices to Connect02.
Shouldnt they have have a different name?
Post #23416
Posted 8/1/2009 5:06:06 PM
Veteran
Last Login: Today @ 2:14:52 PM
Posts: 167, Visits: 3,044
Hi
No , the upper-connect and lower-connect must have the same name , it's normal .
As that they are recognized .
exactly I do not see that 24 vertices , too .
G3 , ok for 28 .
G1 , ok for 28 .
I on the other hand noted an error in this document : http://developer.reallusion.com/whitepaper/G3_update/G3_Update.htm.
Connections for the ankles are not called “connect06” for the 2 , but are the same ones as for G1 and G2 . left : connect 03 ; right : connect04 .
Post #23421
Posted 8/1/2009 7:32:11 PM
So theres a G3 max template? Do I automatically qualify to get the G3 template?
Maybe the G3 has the 28 vertices
Post #23423
Forum Moderators: Visconti
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 2:48pm
Execution: 0.187. 9 queries. Compression Enabled.
