| | | Newbie
Group: Forum Members Last Login: 10/24/2009 12:50:26 AM Posts: 5, Visits: 6 |
| | I created a new project and the project length gets a default of 01:00:02 I then created a CTS which is slightly longer (01:09:54) When I play the clip from the TimeLine, the entire CTS will play (all 01:09:54) but when I play it from the Stage or Output to any format, I only get the 01:00:02 - so the last 9 seconds gets clipped off. I tried using the Export Specified Section and increased the out time to 01:09:54, but the output was still clipped at 01:00:02. I've tried going to Stage and typing in an new number for the project length, but as soon as I click out of the project length box, the number returns to the default 01:00:02. How can I increase the project length to include the entire CTS? Thanks again, Tim |
| | | | Junior Member
Group: Forum Members Last Login: 3/14/2010 9:52:30 AM Posts: 32, Visits: 85 |
| | go into the crazytalk part of forum,i seen the answer there on how to change lenght of audio/wave |
Group: Administrators Last Login: Yesterday @ 11:51:21 PM Posts: 3,801, Visits: 6,294 |
| tglass0000 (7/25/2009)
I've tried going to Stage and typing in an new number for the project length, but as soon as I click out of the project length box, the number returns to the default 01:00:02. How can I increase the project length to include the entire CTS? Make sure you press Enter/Return after changing the project length. This will set the new time correctly.
| | | | Newbie
Group: Forum Members Last Login: 3/8/2010 4:05:02 PM Posts: 12, Visits: 33 |
| | Hi i have just had a go at entering the new numbers and pressed enter/return,and it went straight back to the 01 number,any help please Brian |
| scarrabri (2/13/2010) Hi i have just had a go at entering the new numbers and pressed enter/return,and it went straight back to the 01 number,any help please BrianYou can manually change either the CTS length or the Project Length as descibed above. Project length is changed on the Stage tab and CTS Length on the Timeline tab. Manually entering the time required and hitting Enter/return is the way to set the time so you may be doing something wrong. Obviously Project Length should be equal or longer than CTS Length which might be where you are going wrong. Give it another try. I'm sure it will come clear.
