mtakerkart (2/26/2015)
WOW!! I can't believe this tornado is achieved in Iclone!!!! Is it a prop ? How did you do the dust and particles? If you sell it I'll buy it for shure!
As always , very nice job!
Thanks mtakerart!
Well it is iClone and not iC6 but iC5. I tried to do the cyclone in iC6 using the technique that Arnold Gillespie used in the original film...supposedly he used a stocking and of course his amazing creativity!!
Well I got close with that idea in iC6 using a "Weight-Map" and a cone but never quite worked... maybe if I had Cricky's skills I could have pulled it off. One big problem I have with iClone is with overlapping Opacity-Maps. It just doesn't give me the "transparency" results that I was trying to achieve no matter how I adjusted them. I may post those test so you can see the results. I'm sure someone else can do it correctly.
Anyway.. I used the "Waterfall" particle effect and tweaked it to death then parented it to a spinning object, which I really don't think does that much to help, then parented that rig to a path . I attached another particle effect to give me dust at the base of the cyclone and another particle effect for the debris at the base as well. The animation path allowed me to "lower" the tornado to the ground which was huge in my opinion.
Now this version of the effect could probably have been done in iC6 although there are a few bugs in the Particle generator of iC6 to sort out. But the biggest problem for me is that iC6 runs pretty sluggish on my system (in Quick Mode for goodness sake) even with a pretty simple project....iC5 runs MUCH faster and did with this project for sure
Hope that gives you some ideas!!!
GeForce GTX 980Ti 6GB Microsoft Windows 7 Professional 64-bit SP1 ASUSTeK COMPUTER INC. P9X79 WS (LGA2011)
9 Years Ago by
mark
