Customize your avatar eyes in iClone
Customize your avatar eyes in iCloneExpand / Collapse
Posted 12/3/2007 5:23:32 AM
Group: Senior Forum members
Last Login: 11/11/2009 1:49:20 PM
Posts: 347, Visits: 1,328
I haven't checked if this tip had been already done in forum or tutorials
1) Step1: Launch iClone and then go to CHARACTER - TEMPLATE - 0_MAN
2) Step2: Click the Scene button. Click the Props button. Click the Modify tab. Click the Import button in the Import Props field and browse to the location of the eyes VNS files ( default is C:\Program Files\Reallusion\iClone 2\Template\iClone Template\Eyes)
3) Step3: After importing your eyes 3D props, use Camera Control Bar buttons for adjust it in the scene. Then, Edit your diffuse texture, you can click Launch to open image editors such as Corel Paint Sho Pro, Adobe Photoshop. etc .
4) Step 4
After editing, don't forget to save your texture with its original temp file name.
5) Step 5
Click the Update button to apply the result when you switch back to iClone.
6) Step 6
Keep the result for later use, click the Add button to add the prop to the Custom tab and rename it
7) Step 7
Copy the prop from custom folder to C:\Program Files\Reallusion\iClone 2\Template\iClone Template\Eyes...
8) Step 8: Now you can select your custom eyes for your character:
Click the Head button. Click the Eyes button. From the Template tab, double-click your cutom eyes to apply them to the current character.
You can download the custom eye vns here
David-Josué
http://www.iclone-fr.blogspot.com/http://www.iclonetemplate.com
Post #2188
Posted 12/3/2007 2:21:46 PM
Last Login: Today @ 3:46:19 AM
Posts: 1,141, Visits: 5,331
thanks for the tip david! this is very helpful
merci!
Post #2192
Posted 12/4/2007 7:02:56 AM
You can apply the same process to customize the textures (diffuse and opacity) of your avatar teeth ! In the teeth, the opacity texture is also important!
David-Josué
Post #2203
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 8:13am
Execution: 0.172. 12 queries. Compression Enabled.
