I'm sorry to hear about the theft of your computer. You could try contacting support to see if there is anything that can be done regarding this issue. If you did not have the serial numbers for the products on your computer the long term use of the software will be limited and they will not be able to be re-installed at a later date.
If you wish to to contact support, use the form below.
Peter EdwardsForum Moderator
iClone Daily Blog
