Thank you for any input.
Load the body suit. Then go to upper tab. on the right side click on defused. load the upper defused for the swimsuit. Then click on opacity and load upper opacity. Then click on lower tab and repeat the process with the lower defused and opacity. You won't be able to do the gown swimsuit without the jane gown because the process is the same for it.
Thanks again.
