CT 4.5 Hand Gestures Effects into CT 6
CT 4.5 Hand Gestures Effects into CT 6Expand / Collapse
Posted 6/12/2009 2:54:51 PM
Veteran
Last Login: 3/15/2010 9:53:59 PM
Posts: 146, Visits: 632
Hi:
After lurking for some hours I finally found in one of my backup DVDs this effect that I used with CT 4.5. The app refuses to install because it looks for a CT 4.5 installation. Since I have a backup of the Hand Gestures template ditrectory, Where I can copy it into CT 6 so I can have those effects available? I don't want to install CT 4.5 to solve this.
TIA
Post #21199
Posted 6/12/2009 8:39:21 PM
Last Login: Yesterday @ 10:01:20 PM
Posts: 3,803, Visits: 6,298
I don't have this pack to hand but it will probably go into either ComicEffect or ComicEffectCSM folders which can be found in the Crazytalk 6 Template folder.
Peter Edwards
Post #21214
Posted 6/12/2009 9:11:57 PM
Veteran
Hi Peter:
I try at both locations, no working.
Post #21217
Posted 6/12/2009 9:40:08 PM
Veteran
Hi:
Ok, finally found the proper location. It goes under shared templates/script/Hand Gestures.
Later
Post #21218
Posted 6/13/2009 9:46:37 PM
Glad you got it to work ok.
That is not the common install location for content packs but if it works that is the important thing.
Peter Edwards
Post #21263
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 4:55am
Execution: 0.250. 11 queries. Compression Enabled.
