CloneCloth 3 No longer Upper or Lowers?
CloneCloth 3 No longer Upper or Lowers?Expand / Collapse
Posted 5/30/2009 1:18:56 PM
Veteran
Last Login: 3/15/2010 9:53:59 PM
Posts: 146, Visits: 632
Hi:
I installed yesterday no problem so far. I do have an observation, there are no Cloths for Upper or Lowers. This is different than all previous iClone Clothes (including iCLone 3 Trey, Kane, Trinity and Violet). Please clarify as I find this somehow a limitation unless there is a distint way to work with CloneCloths 3.
Regards!
Post #20691
Posted 5/30/2009 1:35:12 PM
Group: Senior Forum members
Last Login: Today @ 10:02:15 PM
Posts: 1,367, Visits: 6,217
what you need to do is once you load up an avatar, click upper then on materials, click "Load Material" then you should see the folder go G3 cloth, naviate throguh he individual folders, load the ones with the label "TEMPLATE" and then save the new upper to your custom folder
www.animatechnica.com
Post #20693
Posted 5/30/2009 6:21:23 PM
Veteran
Hi:
Thank you. Altough I would expect the cloths to appear at the default template location. But no problem at all will add each upper and lower manually.
Post #20703
Forum Moderators: Visconti, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 10:50pm
Execution: 0.156. 11 queries. Compression Enabled.
