Am I entitled to the 3ds plug in?
Am I entitled to the 3ds plug in?Expand / Collapse
Posted 5/20/2009 6:32:46 PM
Last Login: 2/17/2010 11:26:08 AM
Posts: 70, Visits: 156
I thought I read that if you purchased iClone 3.2 Pro, you will be a Premium member?
From what I can tell, I am a Basic member....
Yes? No?
Thanks,
Ray
Post #20329
Posted 5/20/2009 6:35:38 PM
Last Login: Today @ 3:28:04 AM
Posts: 303, Visits: 2,634
Hi Ray,
You have to register iClone under your account first before you become a premium member.
aT
Post #20330
Posted 5/20/2009 6:38:21 PM
I did register.
When I tried to join the premium, it requested my serial number and then said I was
already registered???
Ray
Post #20331
Posted 5/20/2009 6:42:24 PM
If you're trying to register for CCD to get the plugin, you need to do so here . Does this help?
This is also where you'll log in to get the plugin.
Post #20332
Posted 5/20/2009 7:34:55 PM
This is where I was. It says I am already registered.
When I try to download the plug-in it says "Become A Premium Member"???
Post #20334
Posted 5/20/2009 8:40:03 PM
Ah...I had to go here: http://developer.reallusion.com/dev-about.aspx
and click on upgrade. I was trying to Join!
But looking at the 3ds plugin install document, do I need 3ds MAX for this?
I was under the impression that the plugin simply allows importing of .3ds files?
I don't own 3ds Max!
Ray
Post #20335
Posted 5/20/2009 9:11:15 PM
This is a plugin so you can export models from 3DS Max into iClone format - you would have to have the program already.
Post #20336
Posted 5/20/2009 9:45:03 PM
So it's really a 3ds Max plugin to allow 3ds to save in iClone format?
Post #20338
Posted 5/21/2009 7:53:16 PM
Newbie
Last Login: 3/11/2010 6:38:13 PM
Posts: 1, Visits: 42
rayj00 (5/20/2009)
Yes? No?
Thanks,
Ray
If you have purchased and registered iClone3 Pro then you are a Premium Member. When you login to your account you should see this status showing as below:
You also use those same login details to sign in at the Developer Center. There you can download the plugin and any other tools or documentation you require.
Post #20367
Posted 5/21/2009 10:34:25 PM
Thanks, but since don't own 3ds MAX, it's moot......
Post #20370
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 3:42pm
Execution: 0.203. 10 queries. Compression Enabled.
