bobit_t
bobit_t
Last Active: Last Week
Visits: 202
I'm missing the single dummy file. Where can I find it. On the tutorial it is showing the single dummy as a square blue item. But it seems I can't find it in the downloaded file. I only get the pyramid type which is a Dummy Non Character which is an avatar type but not the single dummy which is I guess a prop or an accessory. Thanks
Last Active: 2 days ago
Posts: 10.8K,
Visits: 40.2K
You will find it in your Content Manger Tab Prop > Avatar Toolkit Vol.2 > Dummy Tool There are 2 Items, Structure_Pair and Structure_Single
10 Years Ago by
vidi
bobit_t
bobit_t
Visits: 202
That's correct i'm seeing two items on that tree currently under the /dummy tools which are the Structure-Pair and Structure_Single but missing is the Single Dummy which is featured on this tutorial "iClone Avatar Toolkit2 Tutorial - Assigning Accessory Roots and Control Handles" where you attached your prop to a dummy which is the square blue (Single Dummy) and that's what i'm looking for. Could be that that's an old tutorial and it's not needed anymore. Please watch that tutorial to see how it was featured on it as a dummy tool.
Posts: 10.8K,
Visits: 40.2K
The tutorials were created before the release of Avatar Toolkit, therefore looks it in the video slightly different
bobit_t
bobit_t
Visits: 202
So which one should i use now as a dummy. Thanks
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
bobit_t
bobit_t
Visits: 202
The only thing is, it is not included in the files that i downloaded when i bought the Avatar Toolkit2. I you have the avatar toolkit what do you use as a dummy file to attach the accessory or prop if incase you want to follow the tutorial. Thanks
Posts: 10.8K,
Visits: 40.2K
You attach props on the structure_single Dummy for single acessories and structure_pair Dummy forEyes Brows ears... e.g. the pair Dummy are 3 Objects . A red cross and and two blue squares
