creating a cloth from photoshop image
creating a cloth from photoshop image Expand / Collapse
Posted 11/20/2007 10:21:27 AM
Veteran
Last Login: 1/1/2008 12:53:52 PM
Posts: 72, Visits: 168
Hello,
Is it possible to create cloth for character whose costume was drawn in photoshop. It is not a photograph of the costume but it is a costume sketch which was hand drawn and then brought to photoshop. Or does the sketch have to be independent of the body?
Bascially I want to know is whether it is possible to create characters whose costumes are designed on computer rather than taking photographs.
Post #1998
Posted 11/20/2007 11:17:51 AM
Group: Senior Forum members
Last Login: Today @ 9:50:37 AM
Posts: 339, Visits: 1,809
The simple answer is Yes! If you have a good quality drawing that you have produced and can bring it through to Photoshop. You will have to have Reallusion's Clone clothe to do this or you could use the default Jack and Jane but these are limited in what you can do. Once you have your Avatar ( Jack or Jane say) go the the upper Modify leaf. Once behind here launch diffuse. This should bring up your texture editor that you set in the preferences. Open your jpg\bmp in your texture editor (Photoshop?) and then drag onto the clothe template. I find the Warp tool handy at this point. Once you have covered the template with your drawing save this as a Diffuse. You may want to make a Opacity too.
You may want to have a look here  http://www.reallusion.com/iclone/ic_tutorial.asp this explains all
Regards
Popeye
www.clones2go.org
Post #2000
Permissions Expand / Collapse
All times are GMT -7:00, Time now is 10:57am
Execution: 0.188. 12 queries. Compression Disabled.
