dangkhoaln
dangkhoaln
Last Active: 10 Years Ago
Visits: 22
Hi, i have many blendshape that i really want to bring them to IClone to animate. I dont know how to bring those blendshape from my model to IClone? Pls Help me, thank you!
planetstardragon
planetstardragon
Last Active: 2 Weeks Ago
Posts: 11.5K,
Visits: 45.9K
Iclone calls them morphs, you do that in 3Dxchange in the morph list. Try this link for more info on this - http://www.reallusion.com/iclone/help/3DXchange5/Pipeline/04_Modify_Page/Face_Setup_Section/Using_Morph_List.htmNote: While it says it's for face, you can morph the entire body and save your morphs with the custom settings panel when you are doing your visemes or expressions in 3DX5
10 Years Ago by
planetstardragon
dangkhoaln
dangkhoaln
Visits: 22
Thank you so much!!! Problem solved! I found that i can bring blendshape from 3DXChange to IClone by creating custom expression group in Facial Expression. But now, custom expression only has 6 group. How can i add more custom group ?
10 Years Ago by
dangkhoaln
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
not sure if you can - if it were possible, it would probably have to be a customized .ini file. a work around would be to save the character as a new name and give it new morphs in the custom settings - less practical, but not impossible. Cheers
