Import FBX from IClone3DXChange to Maya Problem!
Posted By dangkhoaln 10 Years Ago
dangkhoaln
dangkhoaln
Veteran Member (803 reputation)Veteran Member (803 reputation)Veteran Member (803 reputation)Veteran Member (803 reputation)Veteran Member (803 reputation)Veteran Member (803 reputation)Veteran Member (803 reputation)Veteran Member (803 reputation)Veteran Member (803 reputation)
Last Active: 10 Years Ago
Posts: 13, Visits: 22
Hi, I have this character from Maya
Here is my original FBX from Maya. After bring this model to 3DXChange & Convert to non standard Character, I Export this model back to Maya, and receive this problem
The model transformation is changed. Pls Help me, thnks!
10 Years Ago by dangkhoaln
Distinguished Member (32.5K reputation)Distinguished Member (32.5K reputation)Distinguished Member (32.5K reputation)Distinguished Member (32.5K reputation)Distinguished Member (32.5K reputation)Distinguished Member (32.5K reputation)Distinguished Member (32.5K reputation)Distinguished Member (32.5K reputation)Distinguished Member (32.5K reputation)
Last Active: 12 hours ago
Posts: 15.7K, Visits: 30.5K
In 3DXchange you can select which axis is up (Z or Y) when you do an FBX export. If you change the setting, the character should be correct.
dangkhoaln
dangkhoaln
Thanks a lot for your reply. I have solved my problem because I missed that, when exporting from Maya to IClone3dXChange, I have to change Up Axis to Z, instead of Y.
But now, I have a new problem, after I Characterize that character, Export to Maya, everthings is OK, problems are solved. But, when I drag animation from IClone to 3DXChange and Export that character, that character have the issue like issue above, still choose export = Y Axis. Is there any option for animation Up Axis to Y in IClone?
dangkhoaln
dangkhoaln
Can you tell me more clearly about that, I cant fine in IClone "Bake Animation to Bone"?
