3dmax to Iclone problem
3dmax to Iclone problem Expand / Collapse
Posted 11/18/2007 3:56:44 PM
Junior
JuniorJuniorJuniorJuniorJuniorJuniorJuniorJunior
Last Login: 3/30/2008 9:48:16 PM
Posts: 41, Visits: 94
Greetings ,..
i'm using 3dmax 8 , and trying to export a model (Avatar) from 3dmax to iclone using the export plugin ...
and always get problem when i try to import the avatar inside of IClone ...
just as below message
i really wish to get kindly solustion
Best Regards
Spider Mycron
We can always have happy life !
Even living though our illusion !We can always do real illusion !
Post #1953
Posted 11/18/2007 10:20:42 PM
Group: Moderators
Last Login: Yesterday @ 6:05:54 PM
Posts: 1,608, Visits: 2,768
Hi Spider,
There could be many reasons why you are getting the error message depending on what you have done to the model in 3DS Max. If the model is not named correctly, eg Upper, Lower, Shoes etc. If the model has not been rigged and skinned properly with the RL Bones you will have problems also.
The best advice I can give is to read all the developer docs on the subject and watch the excellent video tutorials by Chris Murray which goes through a sample procedure in an easy to follow way. Also make sure you have the correct Max plugin for your version. Using the wrong one can cause problems.
Another thing worth a try is to export to Upper, Lower, Shoes folders and try adding the parts to an existing figure. Sometimes these work when whole characters fail and you can find where the faulty part is.
It is also wise to try exporting one of the template figures without making any changes first to make sure the process is working, then you can move on to creating your own figures.
If you give me a little more info on what you have done in Max I'll try and help more.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #1960
Posted 11/19/2007 1:07:20 AM
Junior
Thanks alot for your very kindly response,
what i did exactly is import .3ds , .obj to 3dmax and immediatelly exported it to iClone and get the problem when i try to import it.
now i will try to template and will be sure how it work,
but is there any guide lines about to to set the charecter fully completed to work for Iclone please ?
Best regards
Spider Mycron
Post #1963
Posted 11/19/2007 5:53:12 AM
Last Login: 11/15/2008 3:22:07 AM
Posts: 497, Visits: 1,178
Hi, Spider
Please download the white paper of "Creating G2 characters for iClone".
http://developer.reallusion.com/docs_ic.aspx
You should work well if you follow the guideline correctly.
If you still can't work out, please send your max file to http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks
Visconti
Visconti
Forum Moderator
Reallusion, Inc.
http://forum.reallusion.com
Post #1971
Posted 11/19/2007 6:04:10 AM
Junior
wow thisis best answer iv'e got for my whole life .. perect support
thanks so much i will follow that link and let you know kindly
Best Regards
Spider Mycron
Post #1972
Posted 11/20/2007 11:27:40 AM
Junior
by the use of iClone 3dsmax templates everything so perfect .. i got exported all models into iClone perfect..
but i'm not able to export poser models ...
i can export from poser to 3dmax (as .obj or .3ds) and when i finish biped i do export to iClone by the plugin .. and it never accept my model
wish to find any solution i work alot onm poser and it help me so much to get model creation
Best regards
Spider Mycron
Post #2001
Posted 11/20/2007 8:25:37 PM
Group: Moderators
Spider_Mycron (11/20/2007)
Best regards
Hi Spider,
The creation of new figures for iClone involves important procedures that must be followed. These include rigging the RL Bones into the mesh, skinning the model with the Max Skin modifier, setting bone pivot placement and setting vertex weights correctly.
Have you done all of the above? You will need to follow the Creating Character For iClone documents that Visconti mentioned above carefully to get all this right. It is not simply a case of exporting a Poser model to iClone I'm afraid.
Pete
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #2004
Posted 11/20/2007 8:29:17 PM
Junior
Thanks alot ..
i found a great plugin for 3dmax , i will do check and get back to you here
many thanks
Spider Mycron
Post #2005
Forum Moderators: Admin,
