Group: Administrators Last Login: Yesterday @ 10:01:20 PM Posts: 3,803, Visits: 6,298 |
| | Hi Jenny, I have temporarily removed this and the other freebies you have posted because they appear to contain copyright content. To be clear, just as you can't share purchased software with others, the same applies to content from the Content Store. You should only share textures for these. I'm sure this is just a misunderstanding on your part, so if you could clarify for me which packs these freebies were made from, I will be able to determine if they are ok to post. You can PM with the information if you wish. Thanks
| | | | Senior Member
Group: Forum Members Last Login: 2 days ago @ 7:33:26 AM Posts: 68, Visits: 381 |
| | When a have a character I downloaded myself as a freebie, can I use that avatar? I understand that a character or avatar from reallusion or so, that I may not use, but when I get permission for using it free,I mean if a download it from a site where you may use it free, is that ok? I have sometimes problems with understanding because I don't speak english, I speak Dutch. Thanks for your patience, |
| | | | Senior Member
| I am glad you can use Deirly, ofcourse I will help you if I can, but don't expect to mutch of me, because I am a beginner you know |
| jenny (5/8/2009)
When a have a character I downloaded myself as a freebie, can I use that avatar? I understand that a character or avatar from reallusion or so, that I may not use, but when I get permission for using it free,I mean if a download it from a site where you may use it free, is that ok? I have sometimes problems with understanding because I don't speak english, I speak Dutch. Thanks for your patience, Hi Jenny, If an avatar doesn't use any copyright content from a pack purchased from the Reallusion Content Store or other 3rd party store then you can share them as long as you have permission from the original creator to do so. If the avatar does contain clothing or content from a purchased pack then only the custom textures should be shared, not the avatar itself. If you are unsure, and to be on the safe side I would let me know what what you plan to share and what the contents are prior to posting.
| | | | Senior Member
| | To be sure, I'll send it first to you is that ok? greetings Jenny |
