There's a lot of good info in this thread! So I won't go into too much detail, but my process is much like everyone else's:
- Each camera shot is a separate project in iClone
(90% of the time, though I do sometimes use Camera Switch when I know what I want to see, and when, or when pesky particle emitters are involved.) And I keep each Scene in a separate folder
(with from 1 to 20+ shots in each.)- Voice Over audio clips in iClone are for lip syncing only, and usually get replaced in the editor with cleaned up, modified versions.
- I used to export as raw AVI, but HD space became an issue, so I now go with the vastly smaller MP4 H.264 in 1080p.
(I have never tried the PNG image sequence route... not sure of the benefits?)- As I build up the shots, I put them into my editor (Sony Vegas Pro) so I can get a feel of the flow of the film as I'm making it. Helps me identify what I might have missed when planning the film. Usually don't edit too much at this point.
- I generally have just the one Project file in Vegas, though I may create a second when it comes to SFX and VO and MUSIC tweaking. One project is easier to alter if I wanted to tweak the contrast/colour of the film, etc.
- When I have all the footage done, I edit and re-watch the film a billion times 'til it's right (or as close as I can get it!)
- Until recently, I would export the finished footage and bring into Sony ACID to work on the sound design, and then music. Now that I have Vegas Pro (and unlimited audio/video tracks) I found I can do the SFX in the same project. If I'm creating the music myself, I still export then use ACID, otherwise I bring it into Vegas and adjust it there.
This is not a hard and fast set of "Rules" on my part, but is generally the way I do things. I'm always open to trying new ways, especially if they work well for others.
https://marketplace.reallusion.com/iclone/author/biggstrek
