iClone 6 Work in Progress Ep.1
12345>>>
iClone 6 Work in Progress Ep.1Expand / Collapse
Posted 4/23/2014 6:00:19 AM
Last Login: 1/19/2015 3:08:59 AM
Posts: 523, Visits: 1,960
Dear all,
As you may know, Reallusion is working hard on the development of iClone 6, and you might be wondering about what sort of astounding improvements it has in store. As a little treat for our users, we present to you a very special ‘iClone Work in Progress’ series. This is the first of a series of videos that will give all of our talented users a sneak peak at how Reallusion is bringing you cutting-edge real-time visual technology in iClone 6 that can help to expand your production potential.
In this first video, we introduce real-time surface smoothing, which essentially smoothes out the appearance of objects and characters in your scene so they look more detailed and of higher quality. Check out the video now!
Real-time surface smoothing is being developed exclusively by Reallusion as our proprietary technology. It enhances the appearance of scene objects without sacrificing system performance.
Previously, the term real-time meant that scene objects had to have a low polygon count in order to maintain flawless software performance. Real-time surface smoothing breaks that mold, and utilizes otherwise dormant resources in your system’s GPU to enhance polygon counts in real-time, which results in the appearance of more visual refinement without a loss in performance.
We hope you’re as excited to check out this new technology as we are to produce it! In next month’s preview episode, we’ll be showing you all about the cool new tessellation technology in iClone 6, so stay tuned!
______________________________________
Bruce (RL)
Forum Moderator
Reallusion, Inc.
http://forum.reallusion.com
Post #184645
Posted 4/23/2014 6:19:33 AM
Last Login: Today @ 1:11:17 PM
Posts: 772, Visits: 11,642
Dynamic smoothing depended from camera distance is GREAT feature!!!
And, as I can see, such subdividing has no effect on original texture layout (UV) -- it's very important for correct visualization!
Looking forward to see how tessellation will be realized. Hope it'll be be-directional as standard displacement (positive and negative) and compatible with displacement maps generated in 3D sculpting applications.
Vit
Post #184646
Posted 4/23/2014 7:40:32 AM
Last Login: Today @ 1:36:46 PM
Posts: 428, Visits: 4,060
Hi Bruce , Hi Peter !
Soooooooooooooooooooooooo Nice to see the work in progress of Iclone 6!!!!!!
Thank you! My money is just waiting you !
Marc
Post #184647
Posted 4/23/2014 7:49:50 AM
Skype ID= learn.iclone
Last Login: Today @ 7:39:36 AM
Posts: 2,320, Visits: 10,869
Just a few questions that come to mind:
Is the load displacement map displayed at approx 1:10 in the clip going to be a GUI interface option to adjust the load on the GPU, or is it just a working guide of the increased load?
Excellent option, but will the increased scales of the smoothing remain with the item on using them inside 3dXchange transfers for uses such as morphs?
Will the increased tessellation increase rendering time?
What affect will the increase to appearance have on soft body physics?
Can the increased smoothing be used as a permanent option preset, or will every scene/project require enhancements?
Once the items "appear" smooth, would the possibility to save the item at a particular level be available, so that each and every time it is used it would not have to be repeated in subsequent projects?
SKYPE ID: rc.650
" I had Alzheimer's (Old Timers), but I can't remember when I lost it! "
Post #184648
Posted 4/23/2014 8:09:17 AM
Hi Cricky,
I can expect that this smoothing based on some DirectX 11 build-in features (functions).
In this case, there is no permanent model subdividing; model dynamically subdivided as pre-processing before final visualization. -- All motions applied on the original model and in each frame the result dynamically subdivided depending from distance to camera and then rendered (visualized).
But it'll be useful to have possibility to export subdivided model using 3DX6. First of all it will help to create more correct displacement maps for "tessellation with displacement" feature.
Vit
Post #184650
Posted 4/23/2014 8:36:13 AM
Last Login: Today @ 1:51:06 PM
Posts: 2,468, Visits: 5,262
Well... I haven't a clue what's going on "under-the-hood" BUT I LOVE IT!!!!!
more, More, MORE!!!!
PROMO-BACK2
Intel Core i7 3960X @ 3300MHz Overclocked to 4999.7 MHz Sandy Bridge 16.0GB DDR3 @ 833MHz Graphic Display HP ZR30w on NVIDIA Quadro 4000 Microsoft Windows 7 Professional 64-bit SP1 ASUSTeK COMPUTER INC. P9X79 WS (LGA2011)
Post #184653
Posted 4/23/2014 8:43:30 AM
Last Login: Today @ 9:26:31 AM
Posts: 4,709, Visits: 7,361
Kudos to Reallusion for iC6 Development WIP presentations
I'll leave the Smoothing technobabble to the Forum Experts.
Is this related in anyway to 3DXChange SKP Model Smoothing?
Does it replace it?
Will certainly be a great asset to us Storyline Editors for whom Object Close-ups have uneven surfaces, irrespective of the number of Prop Smoothing Passes in 3DXChange.
Looks like iC6 retains the current GUI - Good. Albeit Customisable.
      REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS.
Visit www.pinheadhq.com To read all about Pinhead & the Projects.
Pinhead likes visitors to his Website to sign his Guest Book
Post #184654
Posted 4/23/2014 8:58:41 AM
Last Login: Today @ 1:41:08 PM
Posts: 2,812, Visits: 7,363
colour (4/23/2014)
Does it replace it?
I'm not an iClone developer, but I feel confident in saying "No" to both questions.
I believe this is a "GPU trick," for lack of a better non-technical term.  It doesn't affect the actual polygons in the actual model.
It would like if you had a 20-sided "circle," and you look at it and say, "Oh, that looks like it shoul be a circle."
Then it also has to be smart, so your octogon Stop Sign prop doesn't turn into a circle.  That's part of what is magical to me.
iClone6.0 Pro, 5.5 Pro, and 3DXchange Pro
Homebuilt computer - Windows 7, i7-3770k CPU @ 3.50GHz, Radeon HD 6850 Graphics, 16GB 1600 MHz RAM, Asus P8Z77-V Pro motherboard, 240GB OCZ Vertex 3 SSD, terabytes of disk space, and dual 28" monitors.
Post #184655
Posted 4/23/2014 9:02:49 AM
Great job, Reallusion.
Looking good!
Thank you for the preview.  Do we really have to wait a whole month until the next one?
Post #184656
Posted 4/23/2014 9:11:19 AM
Last Login: Today @ 2:10:26 PM
Posts: 1,410, Visits: 8,182
justaviking (4/23/2014)
Looking good!
During the month of waiting you can give your undivided attention to the Pinhead project.
@Bruce and the rest at RL R&D.
Thank you for the info. This is looking very good.
System: Win 8.1 Pro, Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 980 GPU(Driver 344.75), Samsung 850 Pro 512 GB SSD, 6 TB HD storage.
Post #184658
12345>>>
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
Forum Moderators: Visconti, Peter (RL), Bruce (RL)
PermissionsExpand / Collapse
All times are GMT, Time now is 8:17am
Powered By InstantForum.NET v4.1.4 © 2015
Execution: 2.964. 10 queries. Compression Enabled.
