Oh, so that could be the problem! I use PRO because I thought that was the most appropriate and professional package! So if this is what caused my issue with the export procedure I am glad to hear that in deed.
1. Do you personally use the Pipeline and have positive experiences from it?
2. Is this Pipeline version an earlier version of iClone or is it an increased and more broad and expensive version of the program?
3. Does the Pipeline version also have possibillities to handle import of DAZ objects and add motions from iClone to them before I export them back to DAZ?
4. Is it now I will be ruined
I´ll have to check this out at once!
Thanks! I will get back in minutes!
