dddu88
dddu88
Last Active: 8 Years Ago
Visits: 88
Hi all, I created a dance animation in iClone 5 with spring effect on the tail, the spring effect worked very well in iClone 5, On the timeline, I saw the spring had animation data, so I added the animation with motionPlus to Library and saved as a motionPlus file, when saving, I saw the Spring State checkbox was checked from the Motion Option dialog window, after I dropped it to 3DXChange 5, then double clicked on the animation, it played in 3DXChange, but the tail lost its spring effect, everything else worked fine. After I put the animation in Unity, the tail has no spring effect either. Anybody knows what the problem is?
Thanks Dave
Last Active: Last Week
Posts: 10.8K,
Visits: 40.2K
I have not the Problem But my workaround is I send the Model via edit button to 3d xchange . I send the motion plus file via timeline , collect clip, with right click as motion plus into 3D xchange Here a example it is animated with springbones in iClone and now used in Unity rotate with the left mousebutton zoom with the middle mousebutton pan with WASD
10 Years Ago by
vidi
