Tapani (4/14/2014)
Thank you Colour
switching to Quick shading did work. The project size was about 600 Mb, I had to remove objects, after that Pixel shading worked ok but quite slow.
There is no mention what is the disk space which was used and prevented the use of this project. Cache / disk-memory / what else? There is a lot of free disk-space in my computer.
Colour - mentioned somthing about iClone temp-file. I did search it, what is the name of the file and is it ok to delete the file?
Tapani"
See my screenshot for iClone TEMP Folder File Path.
1) Substitute Peter for your PC's Name. Mine is Peter.
2) APP DATA is a "Hidden" Folder, You need to "Unhide" it in Folder Options.
3) iClone TEMP Folder doesn't show in my Screenshot, because the Folder is automatically Deleted each time I run my File Clean-up Program. However, you'll see a couple of iClone Project TEMP Files included since the Folder was Deleted. Which suggests to me that iClone doesn't automatically create a New TEMP Folder. It should. So just Delete the File contained in the Folder. Not the Folder. Those 2 Files in my Screenshot will be automatically Deleted next time I Run the File Clean-up Program. TEMP Files, especially Windows, can build-up, affecting Video Editing, per se.
BTW - You can select a Custom iClone TEMP Folder Directory other than iClone's Default, by browsing to that Directory via iClone Program's Options Pop-up. Where you can easily keep an eye on it.
Screenshot:
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS.
New Pinhead Website & Project to be announced in September 2015
