bobu2357
bobu2357
Visits: 133
There seems to be a change to Goggle 3d warehouse. I can no longer import an prop directly into 3d exchange. I have to first save it to a file then load it into 3d exchange. i could live with that, but i can no longer use 3d exchange to modify it with tool. For example if I want to change the scale of an object i have to type in the scale I want.
These problems arose when i saw a change in Google warehouse format.
Last Active: 2 days ago
Posts: 5.7K,
Visits: 26.4K
The changes to the warehouse, and some suggestions about loading items directly into 3DXchange have been discussed in this thread. Regarding changing the scale of an item, make sure that it is aligned to ground or center. If it is off center then you may not see the Gizmo.
bobu2357
bobu2357
Visits: 133
Thank you for your response. But, ills goes further than not being able to scale. all of the prop (move, rotate, resize, etc) remain stoppled, not alowing me to manipulate the prop at all. I have to export it to iclone. to make any changes.
Posts: 5.7K,
Visits: 26.4K
Any chance that you can post a screen shot something like the one that I posted with a model in it?
RB3006
RB3006
Posts: 2.7K,
Visits: 14.6K
Save it as Obj. and reload it to 3DX. Than you can scale the prop (Hope :w00t Robert
Gruß Robert
DANKE für Haare und Kleidung:, die nicht durch den Avatar geht !!!
bobu2357
bobu2357
Visits: 133
This what I am talking about. I can get the model to exchange, but can't do anything with it.
Posts: 5.7K,
Visits: 26.4K
Weird, I think I found the same model on the Warehouse - but I have all the controls available in 3DXchange and I set the workspace as in your screen shot.
bobu2357
bobu2357
Visits: 133
Thank all of you for your responses. The problem turned out to be that google ware house was not closing automatically as it use to. I found that exchange worked normally after I close google warehouse.
planetstardragon
planetstardragon
Last Active: 2 Weeks Ago
Posts: 11.5K,
Visits: 45.9K
ya, that's the new caveat - what i started doing was surfing through the warehouse through a regular browser now since using the browser in 3DX is now moot, which I don't mind actually because every time the browser in 3DX5 closed, I lost my place - like when I'm auditioning several variations of props ..and want to go back and try another ...much easier with an external browser now to keep my place.
