Character Attachment Properties Choice
Character Attachment Properties ChoiceExpand / Collapse
Posted 11/9/2007 12:08:04 PM
Group: Senior Forum members
Last Login: Yesterday @ 6:43:10 AM
Posts: 473, Visits: 1,019
Would it be possible to make it so that when attaching a Character or an Object
to another Character or Object, there was a choice to have their "facing" or x,y,
orientation remained the same continuously no matter what the angle of the
"part" they were attached to.
That is, if you flew a 1 string Kite, the kite would always, in theory, keep its angle
towards you as it rose so that, when it flew so far up, its angle would no longer be
into the wind and it would cease to climb.
This is how the system works NOW.
Is it possible to have the attached object, in this case the kite, NOT face its "parent"
but rather retain its original x,y, orientation and whether left or right, up or down, it retained
its original orientation or....... "stayed level".
In exactly the same way a Glider would fly on an independent but stable orientation in
respect to the airoplane towing it up front.
Does this make sense???
Application.
Glider being pulled by another aircraft.
Tractor beams.
Car being towed + Trailers etc.
Flock migrating birds.
A plough being drawn by horse through a field
Waitress carrying a tray. (Mild advantage.)
CLICK HERE TO SEE FULL SIZE!
W.I.P. "Medieval Chinese Painting Exhibition" over 6 sets.
iCloneTutorials.com
No Imagination, no comment!
Post #1683
Posted 11/14/2007 3:49:54 AM
Posts: 729, Visits: 1,715
Hi, Neil
Thanks for this inspiring idea.
Indeed, we considered this issue when "link-to" was programmed ifor 2.5.
But the complete inherit function is not applied to iClone yet.
So, if you want to achieve the result as request, it can be done as the following panel in Max, but not in iClone.
Fortunately, users are allowed to set the inherit between objects in the next version.
However, the advanced setting won't be open then. You can refer to the image below to know the exact spec in iClone.
I hope this info is helpful.
Thanks
Visconti
Visconti
Forum Moderator
Reallusion, Inc.
http://forum.reallusion.com
Post #1772
Posted 11/14/2007 8:45:14 AM
Hi Visconti...
I just knew you'd be ahead of me.
To me this is ultimately the most inspiring addition in IClone, Character to Character attachment (& etc. Many things before this were impossible for me.) but this, again,  was a curiosity regarding its evolution re: maintaining trajectory as it were.
Thanks for the insight.
Armstrong.
iCloneTutorials.com
Post #1775
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 11:24am
Execution: 0.203. 10 queries. Compression Enabled.
