How do I create water flushing out of broken pipe
How do I create water flushing out of broken pipeExpand / Collapse
Posted 10/31/2013 9:05:10 AM
Newbie
Last Login: 12/29/2014 6:12:59 AM
Posts: 7, Visits: 129
How do I create this in iclone 5-
A Pipe burst and water flushes out of it gradually with full force..
This is for Doing Previz only.....
Any suggestions will be greatfull....
Post #167458
Posted 10/31/2013 10:10:02 AM
Last Login: Today @ 5:15:54 AM
Posts: 2,818, Visits: 7,388
If your goal is "pre-vis" then the accuracy (visual quality) isn't as important as it would be if you were producing a final product in iClone.
Good.  That gives you more freedom.
I had moderate success using a cloth, and changing the material properties so it was reflective and nearly transparent.
Try searching the forum for "water".
Here's a link to a thread.  The last post on that thread includes a link to a little proof-of-concept video I made.
Someone else did a pretty cool fountain.
One last thing... You can apply a VIDEO as a texture.  So you actually us a solid pipe and then apply a "water" video to the pipe.  For pre-vis work it might be sufficient.
iClone6.0 Pro, 5.5 Pro, and 3DXchange Pro
Homebuilt computer - Windows 7, i7-3770k CPU @ 3.50GHz, Radeon HD 6850 Graphics, 16GB 1600 MHz RAM, Asus P8Z77-V Pro motherboard, 240GB OCZ Vertex 3 SSD, terabytes of disk space, and dual 28" monitors.
Post #167461
Posted 10/31/2013 10:58:10 AM
Last Login: Today @ 12:34:42 PM
Posts: 1,416, Visits: 8,216
There are several "waterfalls" available from the Marketplace - just type waterfall in the search field. You can adjust the size and rate of flow to get something like what you are looking for. Here's a quick example with no adjustments made:
System: Win 8.1 Pro, Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 980 GPU(Driver 344.75), Samsung 850 Pro 512 GB SSD, 6 TB HD storage.
Post #167470
Posted 10/31/2013 11:13:07 PM
Newbie
Thank you....
Post #167516
Forum Moderators: Visconti, Peter (RL), Bruce (RL)
PermissionsExpand / Collapse
All times are GMT, Time now is 8:42am
Powered By InstantForum.NET v4.1.4 © 2015
Execution: 2.184. 10 queries. Compression Enabled.
