To all MAX fans!
To all MAX fans!Expand / Collapse
Posted 2/22/2009 12:27:00 AM
Group: Senior Forum members
Last Login: Yesterday @ 7:10:39 PM
Posts: 624, Visits: 1,268
Super tight dual meshes, are the easy ones!
You wanna do your own?  Easy!
-Jump into MAX 2008 or beyond.  Load the Female07 MAX template.
-Select the upper part, go to edit and hit Clone, selecting "as object".
-In the modifier stack go down, just below the skin modifier.  You will get a prompt to "hold"; do it!
- From the modifier drop down select Push modifier.
- At the push dialog dial type 2.0 and enter.
- Go all the way to the modifier top, to exit.
- Apply some textures to your new mesh, to make it look different from the actual skin.
You got your first Super Tight, poke resistant, "mathematical Upper"!
Do the same, same, with your Lower!
Bingo!   You just have created the newest "first tight mesh in the world"
Export it, and do the tests.  Hey!  THis one does not poke also!  Wow!!!!!
If you still want to go "mathematically" safer: Select each Skin "Lower, upper, hands and shoes parts" (the under layer), go to modifier menu on each, just above the "skin modifier" and apply a push modifier.  This time set the dial to -2.0! (shrink it a little bit!)
Not even Sulphuric Acid can punch this one!!!!
Ain't this world so simple and we want it to be "mathematically complex" ?
NOTE: Per multiple requests, who wants to see the "custom mesh" in action please visit:
http://medialab.galileo.edu/apparition/Heroine.wmv
Mike Aparicio Reallusion Certified Content DeveloperReally Certified
Apparition's Good Friends Gallery - Lucky of me!
Post #15699
Posted 4/1/2009 11:20:32 AM
Veteran
Last Login: Yesterday @ 12:38:51 PM
Posts: 298, Visits: 798
Apparition!!!
TNX for your lesson in how to think re skin tight mesh.. It always give spinoff
effects that are rely superb as an inspiration!
Gorz
  White Tiger Web Shop found at http://www.gallery.swcab.nu/
Animated ANIMALS, live props, live animals, ordinary props, music, freebies and much more....
Post #17296
Posted 6/4/2009 12:47:13 AM
Soon I will get here a good White Paper on more tricks to develop nice things...
Very nice things!
Get your MAX READY!!!!!
Mike
Post #20878
Posted 6/4/2009 9:37:48 AM
Last Login: Yesterday @ 1:00:29 PM
Posts: 313, Visits: 1,190
Thanks for the time you took to write this Mike, I personally appreciated it.
Cheers.
Ricky
Post #20884
Posted 6/4/2009 2:15:46 PM
Veteran
Last Login: Yesterday @ 10:18:07 PM
Posts: 155, Visits: 1,279
Thanks also Mike.
Post #20893
Posted 6/9/2009 1:08:57 AM
Last Login: Today @ 8:39:49 AM
Posts: 523, Visits: 1,280
Now, how to get Max...
Coming soon:
Post #21053
Posted 6/9/2009 1:55:27 AM
you can always use this http://www.turbosquid.com/gmax to make a bunch of really cool stuff ...then download the 3DS demo for 30 days to convert everything as fast as you can!!
Post #21054
Posted 6/9/2009 11:45:08 AM
Now there's a thought...  If I had more friends, I could have each of them take a 30-day trial, one after the other...
I actually do have Max, but it's version 2.5 from when I took classes ten years ago.  I wished somebody would write a converter tool for old versions...
There should be more concern for poor artists... I had to borrow money from my wife yesterday...
Coming soon:
Post #21060
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 11:38am
Execution: 0.500. 11 queries. Compression Enabled.
