problems adding to a set
problems adding to a setExpand / Collapse
Posted 2/15/2009 4:53:22 PM
Last Login: 6/5/2009 11:06:53 AM
Posts: 25, Visits: 81
Hi, I am trying to add grass to a set and I keep getting the message "to render these contents iclone renderer needs to be set to a pixel shader." Can anyone help? Thanks!
Post #15444
Posted 2/15/2009 6:42:34 PM
Veteran
Last Login: Today @ 6:22:45 PM
Posts: 167, Visits: 3,046
Hi ,
You must select pixel shader like this:
I hope this help you
Post #15447
Posted 2/15/2009 7:43:04 PM
Last Login: Today @ 6:13:56 PM
Posts: 3,322, Visits: 5,640
buddhanature28 (2/15/2009)
Your computer will require a graphics card that supports Pixel Shader 3. If you have a supported card then the option to select Pixel Shader will be available as in the image Sen provided above. If not then it will not be available.
You can check the supported graphics card list from the link below.
http://www.reallusion.com/iclone/ic_requirements.asp.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #15453
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 7:37pm
Execution: 0.250. 11 queries. Compression Enabled.
