I want the light to fade from very bright to dark, dark and finally no light. Since the ambient light is not adjustable, how do i achieve this? Do I need to fade to black?
( Use a shallow compressed dark mist in the background distanced just beyond the 50% mark of the set if a night scene. )
Use all four lights to create a sense of overall lighting (or however your concept re: scene elements demand) and in LIGHTS > MODIFY > select ANIMATED LIGHT > EDIT KEY and edit them at the stage you need them extinguished.I'm assuming you know that if at frame 1 a light is set at its brightest and at frame 2000 it is set to about 5% from being off, and then at frame 4000 set again to its brightest, the movie will show almost pitch dark in a slow fade out at frame 2000and then bright again slowly at frame 4000.
This will give you a drop out of lighting to zero.
