Max 2009 Plugin Error
Max 2009 Plugin ErrorExpand / Collapse
Posted 12/30/2008 11:51:02 AM
Newbie
Last Login: 12/30/2008 11:43:38 AM
Posts: 2, Visits: 11
I just tried to install the new Max 2009 plugin.
I got this error message at startup
(all plugins are in the correct location):
"Error loading DLLs:
DLL (...path...)iClone3MaxExp.dle fails to initialize.
Error code 126.
The specified module could not be found.
Please advice what to do.
Post #13652
Posted 12/30/2008 12:03:30 PM
Veteran
Last Login: Today @ 5:56:46 PM
Posts: 205, Visits: 4,128
Hello
You have to update DirectX download this example: dxwebsetup.exe
http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
I had the same problem and everything is back to normal with this update.
Good luck
Post #13654
Posted 1/12/2009 6:55:38 AM
Group: Senior Forum members
Last Login: 1/25/2010 7:56:33 AM
Posts: 51, Visits: 344
Thankyou for the link Sen,
I was having the same problem, and now its all working.
froggy
Post #14096
Posted 1/12/2009 8:20:43 AM
Last Login: Today @ 9:35:03 PM
Posts: 428, Visits: 1,224
Thanks, I had the same issue so I was running the previous version.
I will try it tonight.
Thanks. for the info...
 Join the community of iClone users at www.coolclones.com forum with a wide range of offerings; Hundreds of iCloneFreebies, Tips and Tricks, Tutorials and cordial interaction. The Ultimate mecca for iClone enthusiasts
Post #14097
Posted 1/13/2009 11:10:04 AM
Last Login: 3/15/2010 2:14:46 PM
Posts: 40, Visits: 121
I also was having the exact same problem with the exact same error message.  Couldn't work it out.  Sat looking at the file that wasn't there, virus checked it, redownloaded the plugin umpteen times.  Still no joy.  Sorted now thank you.  Am a happy bunny again
_______________________________________
I'm just a pigment of your imagination.
Post #14132
Posted 1/13/2009 1:03:39 PM
Veteran
Hello ,
I am pleased that your problem is resolved.
But the credit back to support "iClone3 Max Plug-in Quick Guide", or it is noted:
"Note: Microsoft Visual C++ 2008 SP1 Redistributable Package (x86) and the latest DirectX End-User Runtimes should be installed before running the plug-in."
Well, as I even tried a little on the net for this problem, because like you, I thought I directx updated.
Post #14135
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 9:54pm
Execution: 0.219. 10 queries. Compression Enabled.
