How to set preference to "pixel shading"?
How to set preference to "pixel shading"?Expand / Collapse
Posted 12/23/2008 1:58:17 PM
Newbie
Last Login: 12/30/2008 1:26:37 PM
Posts: 3, Visits: 9
Every time I choose or apply "water (look at the image below)" from the tab menu of iClone3, a message from iClone reminder keep on appearing saying "This scene contains LivePlants or water. To render this contents, iClone renderer needs to be set to Pixel Shader."
How can I set the preference to "pixel shading"? Because when i went to preference and clicked "pixel shading", the black dot doesn't set or apply it to "pixel shading (look at the image below)."
Post #13457
Posted 12/23/2008 2:29:40 PM
Group: Senior Forum members
Last Login: Today @ 10:20:41 AM
Posts: 1,091, Visits: 4,898
I am afraid this looks like a graphic card problem and your Graphic card may not support Pixel shader 3. You need to check this I would think!!
Post #13458
Posted 12/23/2008 2:45:08 PM
Newbie
Posts: 3, Visits: 9
Popeye (12/23/2008)
I am afraid this looks like a graphic card problem and your Graphic card may not suppoer Pixel shader 3. You need to check this I would think!!
I see, I'll check it out. Thanks!
Post #13459
Posted 12/23/2008 7:46:52 PM
Posts: 3,319, Visits: 5,635
markelases (12/23/2008)
Please take a look at the link below and check which graphic cards support Pixel Shader. It would appear yours does not and if so you will be restricted to Quick Shader sadly.
If your graphic card is listed as supporting Pixel Shader then please ensure you have the latest drivers installed for your card. This can make a difference.
http://www.reallusion.com/iclone/GraphicsCard.pdf.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #13462
Posted 12/23/2008 8:07:27 PM
Newbie
Posts: 3, Visits: 9
It seems that I don't have the latest driver for my graphic card. I'll try to get one later. Thanks!
Post #13463
Posted 5/19/2009 6:19:10 PM
Newbie
Last Login: 5/23/2009 10:29:48 AM
Posts: 3, Visits: 4
And how we can check our video cards?
Post #20256
Posted 5/19/2009 7:32:01 PM
lbonocchi (5/19/2009)
In Windows XP just select Start - Run -Dxdiag.exe. Then choose the Display tab. (In Vista just press Start and then type Dxdiag in the Search Bar)
Once you know your graphics card you can look it up in the document below and see what Shader options you will have available.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #20259
Forum Moderators: Visconti, Peter Edwards
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 10:27am
Execution: 0.203. 9 queries. Compression Enabled.
