Group: Administrators Last Login: Yesterday @ 1:51:12 AM Posts: 729, Visits: 1,715 |
| | BSM (Bone System Modification) This unofficially documented feature is originally designed in-house to fine tune the motion applied to characters with varied body scales. However, we found it can be very helpful to re-shape the behavior of a character, eg. make it looked more macho, croocked, relax, or tense, etc. simply by adding subtle joint rotation offsets. Thus, we determined to disclose this trick here. Here is one example
Ape
Proud
Sad
You can download the above BSM files (In the post attachment) and compare those characters behavior by applying different motions.
Download the sample bsm files for each characters - load them in the same character folder, and match your character vns file to the bsm name Handling Embedded BSM Data If you create a new custom character orginally comes with the bsm description, the BSM data will be embedded in the newly created charater. The same rule can also be applied to project files which contain characters with BSM description. After BSM data get embedded into character or iclone project, you can not find the corresponding bsm files in the target folder. Here is how you can retreive the BSM data once you want to adjust further: a. First select the target character by double clicking the target character in the 3D view window. b. Now, press Ctrl-B, you will see a file saving dialog, then you can save it as a bsm file that you can edit by any normal text editor. c. If you have any change in the bsm script, simply reload the character then the new behavior will be updated.
Visconti Forum Moderator
Reallusion, Inc. http://forum.reallusion.com
Group: Senior Forum members Last Login: Today @ 11:07:19 AM Posts: 1,091, Visits: 4,899 |
| Nice new tool and very easy to use. Well done RL
Group: Senior Forum members Last Login: Yesterday @ 6:43:10 AM Posts: 473, Visits: 1,019 |
| | This is really intrigueing. Appreciated that you included it. Question? Will this ability be available as a control system within iClone v3???
CLICK HERE TO SEE FULL SIZE! W.I.P. "Medieval Chinese Painting Exhibition" over 6 sets. iCloneTutorials.com No Imagination, no comment! |
| Hi, Neil
Good question... Actually, we won't provide a control system specially for BSM. BSN is designed to correct the performances of different characters applied with the same motion. In iClone 3.0, there'll be a flexible system to edit your motion (the concept of "Motion Layer"). So, you can create a seris of motions easily like: Stand > Walk sadly > Walk proudly > Turn one's head
It seems that your motion editor will upgrade from "Painter" to "Photoshop".
Thanks Visconti
Reallusion, Inc. http://forum.reallusion.com |
Veteran
Group: Senior Forum members Last Login: 11/15/2009 7:57:05 PM Posts: 278, Visits: 1,278 |
| Visconti... this is an excellent tool to put in our hands. Just what was needed to make those little tweaks. THANKS!
------------------------------------------------------ Life is a journey. Where is your life taking you? ------------------------------------------------------ www.iclonerevolution.com www.mdmccallum.com |
Veteran
Group: Forum Members Last Login: 3/13/2009 6:17:05 AM Posts: 175, Visits: 640 |
| looks like a good tool, but it is byond me how to use it. i did download the attached file and tried, but did not figure it out. btw. the g2 characters do not seem to have bsm data, the g1 do. help appreciated.
my imaging rants and other mad stuff |
| Hi, Beruply
It would be easier to find them if you enlarge them before attaching them to somewhere. And you could modify them in Props timeline.
Indeed, the G2 characters should be without BSM files. That's because BSM files are initially developed to adjust the default poses which make G2 look great, but might be inappropriate for G1. BSM file can help define the default look or style for specific character.
Thanks Visconti
