Group: Administrators Last Login: Yesterday @ 1:51:12 AM Posts: 729, Visits: 1,715 |
| | Direct Picking and Manipulation ‧Double click to select target characters or props, the selected object will be marked with a yellow bounding box. In the mean time, the corresponding Modify panel shows up ‧Hotkey object manipulation: 。move: Alt + arrow keys 。rotate: Ctrl + left / right 。up and down: Ctrl + up / down 。hold Shift key to 10X increase the operation speed
Enhanced Camera System ‧Auto snap camera: after you double click selecting the target object, press F (Front) key or Home (Perspective) key to snap camera right on the target. Now you can easily rotate the camera around the target object. ‧Large scene camera, no clipping on sky dome ‧Access the Long shots templates from \Long shots folder, you can quickly switch long distance camera to overview the scene. ‧To create your custom camera view, turning on Edit Key option and add your new camera to the custom panel.
Link-to Feature between characters, props ‧Easy to allow characters ride on a horse or drive a car. ‧Easy to link objects together and move them in the same time. ‧Be able to easily use helper to animate any scene elements. 。eg. Universal Car Wheels Helper
Enhancement of Character animation with BSM description ‧BSM (Bone System Modification) is a motion filter which allows you to offset the joint rotation when any motion applied. ‧You can easily modify the parameters stores in the bsm file with any text editor ‧In iClone2.5v, the included G1 characters all come with their bsm file for motion enhancement
Know more about BSM
Better Initial Pose and Default Idle Motion
‧The character appears more friendly with relaxed arms placement.
The followings are some of the usual Hot Keys you can use in iClone.
A, S, D, F, G, H, J: Camera Angle F9: Preview F11: Full screen Ctrl+F7: Add character, rename character, or delete character Ctrl+F1: Toggle between pixel shader and quick shader Ctrl+F: Show frame rate and shader status Ctrl+G: Show floor grid
Additional: New Hot Keys in iClone 2.5: After picking, you can Ctrl+←: Turn left Ctrl+→: Turn right Ctrl+↑: Move up Ctrl+↓: Move down Alt+←: Move left Alt+→: Move right Alt+↑: Move backward Alt+↓: Move forward Ctrl/Alt+Shift+(direction) : speed up the movement
If you would like to know the entire Hot Key list, you can refer to iClone Manual. Just press "F1" in iClone to call out the iClone Online Help. Then take a look at the item- "Keyboard Shortcuts" below the item-"Tips and Suggestions".
Users' showcases made by 2.5 in CoolClones
Visconti Forum Moderator
Reallusion, Inc. http://forum.reallusion.com |
Group: Forum Members Last Login: 10/14/2009 3:26:12 PM Posts: 82, Visits: 726 |
| Many thanks for this posting. It helps very much to start and understand work with iClone
Andi
PS: Meine Erfahrungen mit der Einarbeitung in iClone in deutscher Sprache in meinem Blog. |
