Walking on a raised surface?
Walking on a raised surface?Expand / Collapse
Posted 12/20/2008 3:13:29 AM
Last Login: 12/25/2008 11:37:01 PM
Posts: 20, Visits: 39
ok, last st00pid n00b question for a while... probably...
when i have characters walking on raised surfaces such as pavements etc, they "sink" part way through the animation
at the start of the walk cycle i set Avatar/Transform/Move Z to, say, 8. i also set it to 8 at the end of the walk cycle (and nothing in between). however, after a few frames the system has decided to set it back down to 0
the only solution i've found so far is to manually set the first few frames to 8 - after that it seems quite happy to keep it at 8 for the rest of the cycle
anyone else have the same problem? any better solutions than the one i've come up with?
Hieronymous Crowley at: Art of Darkness
Post #13332
Posted 12/20/2008 9:04:09 AM
Posts: 3,319, Visits: 5,635
Which version of iClone are you using?
This being the iClone2 forum I would assume IC2 but you mentioned in another post you had iClone3. As answers to questions can be very different depending on the version, I just wanted to check.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #13341
Posted 12/21/2008 1:18:45 AM
Peter Edwards (12/20/2008)
oops. my bad
yeah, i've got iClone 3. i think i meant to post in "Hints and Tips", as i can't find any other suitable place for these kinds of query
Post #13348
Posted 12/22/2008 7:39:49 PM
No problem. It does take a while to get used to the layout of the forum.
If in doubt, post your questions in iClone - General.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #13432
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 2:23am
Execution: 0.156. 9 queries. Compression Enabled.
