Group: Forum Members Last Login: Yesterday @ 11:05:42 AM Posts: 6,551, Visits: 13,038 |
| I think this is a limit of your graphic card .
I can even choose 8192x8192.
quote from CTA Guide
Maximum real-time map size
This setting decides the resolution rendered in the working area. If you encounter a blurry result, especially with image-based items, then try to increase the value of this setting to render the working area in higher resolution.
liebe Grüße vidi
„Um ein tadelloses Mitglied einer Schafherde sein zu können, muß man vor allem ein Schaf sein.“
Albert Einstein
Group: Administrators Last Login: Yesterday @ 12:33:22 PM Posts: 8,786, Visits: 13,591 |
| Nop3D (4/29/2012) Hi Vidi,
I update graphic card driver already (Intel G33/G31 card) but the problem still exist.
How can I send image file to you for analyzing further ?
Please help.
Thank you
Hi Nop3D Unfortunately the graphics card is the problem here. The Intel G33/G31 graphics chips are quite old now and underpowered for CTA. If you have updated your graphics drivers and set the Max Real-time Map Settings to the highest available, then there isn't much you can do to improve the situation apart from getting a newer and more powerful graphics card. Sorry I can't offer better news.
Peter Edwards Forum Administrator www.reallusion.com |
| | | | Junior Member
Group: Forum Members Last Login: 5/2/2012 8:00:48 AM Posts: 30, Visits: 154 |
| | I noted, thank you again Vidi and Peter |
