Need more dots on mouth.
Need more dots on mouth.Expand / Collapse
Posted 11/12/2008 12:37:25 PM
Newbie
Last Login: 12/1/2008 4:02:40 PM
Posts: 3, Visits: 10
Why do I sometimes only have like 3 white dots and no yellow dots for the mouth area located on the wire..It doesnt happen all the time..Thanks...bill
Post #11709
Posted 11/12/2008 1:04:13 PM
Posts: 3,319, Visits: 5,635
The number of fitting points you see is determined by the mode you are in. In Basic Facial Mode you will have 3 fitting points and if you select Detailed Facial Mode you will have either 7 if the mouth is closed or 10 if the mouth is open.
The image below shows where you switch from Basic to Detailed. The help guide covers this in detail so I would spend some time going through it to get a better understanding of the process. Just press F1 when in Crazytalk.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #11711
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 10:24am
Execution: 0.109. 10 queries. Compression Enabled.
